 Problem with upload pictures
Problem with upload pictures Empty
PostSubject: Problem with upload pictures   Problem with upload pictures EmptyFri May 25, 2018 8:17 pm
Since a few minutes i have a problem to upload pictures. This is written:
Fehler: Umleitungsfehler
Die aufgerufene Website leitet die Anfrage so um, dass sie nie beendet werden kann.
Dieses Problem kann manchmal auftreten, wenn Cookies deaktiviert oder abgelehnt werden.
or english:
Error: redirect Error
The called Web site redirects the request so that it can never be terminated.
This problem can sometimes occur when cookies are disabled or rejected.
PostSubject: Re: Problem with upload pictures   Problem with upload pictures EmptyFri May 25, 2018 8:35 pm
Andreas, ich habe es eben ausprobiert. Genau diese Meldung bekomme ich auch.
I get the same message.
Yvette
PostSubject: Re: Problem with upload pictures   Problem with upload pictures EmptyFri May 25, 2018 9:09 pm
Sicher wegen dem neuen Datenschutzgesetz.
PostSubject: Re: Problem with upload pictures   Problem with upload pictures EmptyFri May 25, 2018 9:41 pm
Vielleicht, jetzt klappt es aber wieder. Habe es gerade getestet.
Problem seems to be solved now.
Yvette
PostSubject: Re: Problem with upload pictures   Problem with upload pictures EmptySat May 26, 2018 8:15 am
Yes, the same here :)
PostSubject: Re: Problem with upload pictures   Problem with upload pictures EmptySun May 27, 2018 12:27 am
It seems it was just a temporary thing. I am glad everything is working perfectly now. Very Happy
~ Rogério [You must be registered and logged in to see this image.]  [You must be registered and logged in to see this link.] [You must be registered and logged in to see this link.] [You must be registered and logged in to see this link.] [You must be registered and logged in to see this image.]
PostSubject: Re: Problem with upload pictures   Problem with upload pictures EmptyMon Jun 17, 2019 5:38 pm
Now are problems again
PostSubject: Re: Problem with upload pictures   Problem with upload pictures EmptyMon Jun 17, 2019 11:59 pm
Do you keep having problems? Roger just uploaded pictures just after your post using the forum hosting service as you can see [You must be registered and logged in to see this link.]
PostSubject: Re: Problem with upload pictures   Problem with upload pictures EmptyTue Jun 18, 2019 6:40 pm
Yes, for a few hours there was "error", but later it works again
PostSubject: Re: Problem with upload pictures   Problem with upload pictures EmptyFri Oct 04, 2019 7:11 pm
Now are problems again. The upload start for a short moment but dont will finish
PostSubject: Re: Problem with upload pictures   Problem with upload pictures EmptySat Oct 05, 2019 3:39 pm
works again
STS Forum  :: Life on STS :: Problems and solutions-
